Re: charging troubles
Posted by JohnB on February 07, 2017 at 07:32:53 [URL] [DELETE] :
In Reply to: Re: charging troubles posted by Tim Daley(MI) on February 07, 2017 at 05:34:55:
Tim,
I was measuring voltage at the generator with the regulator disconnected. As one would expect, the voltage output was proportional to RPM (up to about 20Vdc). From what I know about gennys, this makes sense. I didnt measure the maximum current output, but when I "full fielded" the genny while connected to the regulator, the ammeter would register about 10 amps, which jives with the specs you provided.
