Re: charging troubles
Posted by JMOR on February 06, 2017 at 21:39:06 [URL] [DELETE] :
In Reply to: charging troubles posted by John B. on February 06, 2017 at 18:37:15:
The relay that has normally open (at rest) contacts is the cutout and it has heavier/larger contacts than the field control relay. The Field control relay contacts are normally closed (at rest). Those field contacts will open magnetically when battery voltage is high enough that it is not in need of charging.
