Re: 1954 Ford 600 Tractor.
Posted by Den N Ms on February 05, 2017 at 15:54:17 [URL] [DELETE] :
In Reply to: 1954 Ford 600 Tractor. posted by Mark Fitzwater on February 05, 2017 at 09:25:53:
Mark,As others have mentioned,check for vacuum leaks at carb mount,manifold to head,or even the intake manifold itself.Remove intake tube from the air cleaner at he carb and give it a shot of starting fluid in the carb for a start up then spray around carb connection to manifold and manifold to the head.Listen for change in the engine and for leaks.
