Another Trans/Hydraulic fluid change ?
Posted by Don B. on February 03, 2017 at 07:36:41 [URL] [DELETE] :
I am getting ready to change the fluids on my '41 and I was doing some research on fluids and came across a site that gave tips on the changing of the fluid and it said that to properly fill the fluid is to take the bottom bolt off the inspection plate and fill the fluid until it starts to seep out where the bolt hole is then stop because that indicates that there is enough fluid, is that accurate and the way to do it?
If not, what do you recommend, I want to be sure I get it right?
Thanks,
