Re: Lord Loader info
Posted by Kirk-NJ on February 01, 2017 at 13:27:43 [URL] [DELETE] :
In Reply to: Lord Loader info posted by Roger on February 01, 2017 at 11:56:31:
If it mounted on the 850 it will fit your 841. Make sure you get all mounting brackets.also when you are lifting the 800 lbs you will need wheel weights, loaded tires or something hanging off the 3pt for counter balance.
Kirk
